Hello again,
Sorry for starting 2 threads in a row, I just thought it would keep things cleaner.
I built a module with 2 system100m LFOs, using this stripboard layout:
Now the square output gives me a healthy 10V bipolar oscillation, but the triangle on both builds only goes up to 4V. Is there a reason for that? can it be fixed?
Im pretty sure that the triangle is supposed to be lower as the amplitude of the wave is half that of the square and I see nothing on the schematic to amplify it.
Not an expert bit we all moan the triangle is quieter.
Just keep having fun and asking questions. There are no silly questions here. Just folk who are all in the same boat.
Read up on the many uses of the op-amp there are many ways you could modify the circuit to amplify the triangle output. Enjoy.
Never built this but I’ve looked at a simulation and indeed the triangle amplitude is much lower than the square. By the way, this circuit has no discernible resemblance to the actual Roland 100M LFO.
For a couple of similarly simple LFOs that may give a better triangle see:
(the latter goes on to add a sine wave shaper which about doubles the size of the circuit but that can be left out.)
(Never built those either but they look reasonable.)
Thanks guys,
Yes it’s strange this was called a system100 lfo…
I have found 2 stripboard layouts using the same schematic, both called system100
I guess that’s how you start legends on the web!
Thanks also for the other lfo designs, I’ll save them for future builds.
This whole stripboard thing takes me back to my teenage years building stompboxes, love it!
Oh… Just noticed this remark on the Kassutronics page:
The triangle and sine wave have about 5 V amplitude, the square wave goes full swing of the opamp, about 10.5 V.
The Haillant one has an output gain stage with a variable gain so you can crank it up to ±10 V. Of course nothing stops you from doing the same with the Kassutronics or the “100M”.
Well, that’s what the circuit does The part to the left is an integrator that charges (or discharges) the capacitor, the part to the right a comparator that switches the integrator polarity when the input hits zero. The exact point where that happens depends on the resistors in the feedback loop. You can tweak the resistor values a bit, but adding an extra buffer is probably easier.
Simulation of this “100M” LFO tells me not only is the triangle amplitude smaller, which you can fix with a gain stage, but it’s frequency dependent, which you can’t. A rather bad characteristic for an oscillator to have. The Haillant LFO’s triangle wave is larger (I’m getting about ±8 V) and doesn’t depend on frequency.
