At the moment I have no money, so no order, no solder so no construction ! , but I have that in mind all days, and I continue in my head and with research my preparations for future modules.
I make some adaptation from schematic to a stripboard format on paper like this
II think that if i could clean it up with a software, once verified it would be usable to share (with my disgusting paper everything is not understandable )
What do you use please (free / open source off course)
Thx
On a side note funny thing is that it is even cheaper to create and order stripboard from JLCPCB than to buy it from a supplier. In your place I would start to design my boards in kicad and then order all of them when you get the resources. You can create a stripboard design in kicad.
There are xs on the +5V pins of the header, which I take to mean they’re not connected, so that strip is being used for another purpose (connecting the resistor from -12V to the LED). But why not just use a 2x5 header? Also, all 6 header ground pins should be connected to ground (which would require some strip cuts).
Speaking of strip cuts, aren’t there any? I mean, there must be some under the op amp, which they oddly have not shown. None elsewhere?
Quickly looking over it it seems to be voltage divider to give you -5V to power TL072.
Correct me someone if i’m wrong.
EDIT: Yeah I overlooked it and made up something completely stupid.
