I think fredrik’s reply to your similar question in April answers this one too.
Also, I look on Mouser for 33 ohms, ERJ-xE, and I find 3 entries of which two are in stock: https://www.mouser.com/ProductDetail/Panasonic/ERJ-6ENF33R0V?qs=50QC8w71jAtDItwiTe6iYQ%3D%3D and https://www.mouser.com/ProductDetail/Panasonic/ERJ-8ENF33R0V?qs=8%2BG0TiN%2FgVpb1yH%2F8k6uQg%3D%3D (0805 and 1206). Did you need 0603? That one is out of stock. So see fredrik’s answer.
Note on Mouser you can click the check box next to a listing for two or more parts and then hit the compare button to get a side by side listing of specifications.
ERJ-3R is rated for 50V vs 75V and lower temperature range, both of which presumably don’t matter, and is 0.5% tolerance vs. 1%, so is better in that regard.
