Hello everyone,
I’m trying to design a resonant HPF and I need some help. After trying some circuits with no success, I’ve decided to use a AS3109 chip that I have available.
I’ve been looking for examples online, but I can only find low pass filters. So, crossing a design for the AS3109 as LPF and a design for HPF using a similar chip (AS3320), I’ve come up with the following circuit (excuse me for the messy schematic, I’m still setting up my libraries).
I’m not sure if it will work, so it would be great if you could tell me what you think. I don’t know if I’ll use the four stages or if maybe two are enough. Also, I’m aware that I might need to adjust the amplification/attenuation of the signals to make it work as intended. At the moment it’s just a sketch.
I haven’t been able to set up the circuit myself yet, since I’m missing some capacitors. I’ll buy some next week and give it a try. Meanwhile, any advise that you can give me will be truly helpful.
Thank you very much
