Hello guys, did any of you build Sams MS20 Filter WITH HP/LP switch on a strip board? I tried it, but it didn’t work, without the switch it works wonderfully. And it hasn’t changed much, a capacitor has been shifted and another plus switch has been added, you can’t go much wrong with that?!?
When I flipped the switch I just got no sound. And I had read somewhere that there were probably problems with it. I then converted the version back to the normal version without HP, but wanted to try again now
At the bottom is the layout, I’m building it all over again and hope that it works this time. I can’t say why it was the last time either, because I rebuilt it pretty quickly to the version without HP
I built it on stripboard, but I def had issues. It’s working now, but I could never quite determine what I did wrong. I just rebuilt it, making sure to ground everything and be sure if all the connections and it worked just fine.
We talked about it the other day, remember? you sent me the great layout with the explanation in which direction the LEDs must be. Do you remember? I’m attaching this picture again because it really helped me.
And yes, I know the filter behaves like this, thanks.
