Hello everyone
I’m trying to rehouse my zoom bfx-708 bass multi effect pedal, to make it a bit sturdier
The expression pedal works with this (unknown) 4 pin optical sensor. Using the diode mode of my multimeter gives me the following results:
Pin 1-2 Vf= 1.3 volt
Pin 2-1 Vf= 0.93 volt
Pin 2-3 Vf= 0.85 volt
Pin 4-3 Vf= 0.85 volt
Pin 4-1 Vf= 0.93 volt
Pin 2 and 4 are connected to ground.
Moving the pedal does not change the relative voltages, however, there is an empty variable resistor spot on the pcb. The 3 pads are connected together, but swing between 0.4 and 0.8 volts when moving the pedal.
(You can see the 4 conductor ribbon cable and the VR connections in a triangle shape)
I’m trying to find a way to make this work with a potentiometer or external expression pedal.
Can it be done?
I was thinking to create a 0.4 to 0.8 volt reference and connect a pot as voltage divider between it.
Any help would be so appreciated
