I found this pedal (I know it is just a switch, not a pot… yet…):
It looks like it is screwed together, so should be easy to gut and replace the innards with a pot and some 3D printed gears.
So my question is : Is the travel big enough ?
It looks a lot shorter than on “genuine” expr-pedals.
What do you think ?
I’d have to say no. You may get enough travel for a two or three stage switch like they used in the early organs. That said anything that moves could use dial cord (like the old radio dials) and then it’s just a case of having enough space to increase the diameter of the pots.
I often get ideas looking at parts and materials especially ones that mean using the part in an unintentional way. To me it’s a major part of the fun. Sing out if you spot anything else.
Now JFDI
I printed this one a while ago. It is small, ehm. I’m sorry I’ll say that again: it has a small foot print But it works. The design is from thingiverse.com:
Look much more sturdy.
But also so much higher… is that comfy having one foot so high ?
(I mean, I have never used one… I really don’t know much about pedals)
Looks like the 3D printed pedal is just slightly thicker than the M-audio one.
The M-Audio is articulated at the “back” and you have to push it down with your heel ?
And the 3D printed one you push down with your toes ?
I clearly prefer the second way, that’s how the accelerator on my car work
I think I will just put the one I found in my next order and see what can be done with it, it’s not even $7…
