My Dual Diode Ladder VCF
Finally posting the end result of my VCF build!
This is a Moritz Klein inspired dual VCF. Each filter has essentially two cutoff knobs: the smaller one on the side and the center one, which is a dual-gang potentiometer. This way I can bias each side’s cutoff frequency and control both at the same time with the big knob at the center.
I also added voltage control to Drive and Resonance via internal diff-amp VCAs.
There is a switch to link both filters to Filter A cutoff CV, and another switch that does the same to the Drive and Resonance CV. There’s also a cutoff CV input normalled to the V/Oct CV trace on the power bus.
All Filter B input jacks are normalled to their Filter A equivalents, and all CV inputs have attenuverters (except for the V/Oct one, which can be attenuated to x0, x1/2 or x1/1 V/Oct wtih another switch on the front panel).
I’m pretty happy with the sound, visuals and ergonomics.
The KiCad project can be found here: GitHub - DeMarco/DMH-Dual-VCF-Diode-Ladder-Mk2: Version 2 of my dual Diode Ladder VCF module
Here’s a demo and some more pictures:
Next challenge: Dual Voltage Controlled Envelope Generator, so that I don’t need to use the one from my Moog Grandmother anymore :stuck_out_tongue:
What a fantastic filter. Amazing work!!
If you ended up with spare boards, PM me please :slight_smile:
I too would love one!
saw this on GH a while ago and was very interested, glad to see it got finished. What a beauty!
“GH”?tiny
it’s the hub of git yo
@danbass , @krztoff and anyone else building this, beware of a change I made after my first build, which I think is not present in the original Gerbers: you should use C-tapered pots for Resonance control. Linear B-tapered pots produce almost no effect between 7 and 12 o’clock and make the usable range a bit finicky to play with.
Here’s the one I used: https://www.taydaelectronics.com/potentiometer-variable-resistors/rotary-potentiometer/anti-log-reverse/c100k-ohm-anti-log-taper-potentiometer-knurled-plastic-spline-shaft-pcb-9mm.html
A more elegant solution (to make it less dependent on specialty pots) would be to design an exponential VCA to control the resonance, but I’ll leave that to a (far-)future Mark 3 version :stuck_out_tongue: .
