So I spent a couple of hours today attempting to get the WSG oddness filter section working. Unlike yesterday, we had some success. At lunchtime I stripped out all of yesterday’s mistakes and rebuilt it, but the effect was the same, just loads of something-not-grounded noise. I ended up checking the POTs with the multimeter to check that they were actually working, as they didn’t appear to do anything.
So I had another go this evening, stripping everything out and putting it back again. Firstly, I left out the POTs and reduced R11 from 750k by putting another in parallel, based on only using one voice. I was convinced that the signal hitting the op amp was so low, it was just amplifying noise, rather than a clean signal. With this in mind, I also replaced the 10M R4 with another 750k and this appeared to pass through all the weird noises from Voice A without any background hum.
So I wired the POTs back in, leaving the modified resistors, but the weird noises were gone. I tried changing a few values of R4, to no avail. In a last gasp try, I put the 10M resistor back in, and was greeted by oddly filtered weird noises.
It took a while to figure out what was going on, but at some point during all the fiddling, I must have flicked some of the switches and twiddled some of the knobs on Voice A. This appears to be enough to override the noise and allow whatever is being sent to be filtered, especially if the R3 coarse oddness filter is whacked all the way round.
This all making me think that there is an issue hidden somewhere within Voice A, rather than the filter. Although I don’t like the way the noise changes in loudness as I waft my hand over it. Probably time to take everything out and put it all back again while triple checking I’m doing it correctly…
Edit: realised this morning that there’s probably nothing wrong with Voice A, and it’s probably an issue with the oddness filter. Without the filter installed, when you unplug the power, it continues to makes fainter and fainter noises for about thirty seconds. With the filter installed, it goes dead the moment you pull the power. Shirley this means I’ve got some sort of drain somewhere that I’m not aware of, but where…!?!
