Hi folks,
I’m back into building and modding sections of my synth after a big contract job ate my life for a few weeks and I’ve suddenly realised (I don’t know why it took this long) that my MS20 filter (similar to the LMNC filter, based on the Eddy Bergman design) doesn’t fully open the cutoff frequency with eurorack standard 5v CV levels.
I’d imagine this is because the Korg MS20 operated on a 10v or more CV level, but being that we’re building in KOSMO which is electrically eurorack underneath, I’m surprised so many seem to still be using this design. Is it perhaps because many use the Beatsteps which have very hot 12v CV levels so they don’t notice?
Here’s LMNC’s design:
I’m wondering (apart from adding another op-amp in line with the CV input) what the best scenario might be in terms of allowing this 5v input to feed the filter properly? If I lower the input resistor (100k - feeding the BC558), that would take us out of standard best practice input impedences. I also could increase the resistance pulling us down to ground (currently 1.8k) and add resistance to the 12v feeding the cutoff potentiometer to essentially make it a 5v source, but I guess this could also have some unintended consequences…
Any hints or thoughts? It seems like this would be something pretty important so we have full range at Eurorack CV voltages.
EDIT:
Actually, partially answering myself here as the coffee kicks in:
Using a voltage divider calculator, it looks like if we dial the cutoff all the way up with the 12v-sourced potentiometer so it’s feeding out directly 12v, once that passes through the 100k resistor, and is pulled down by the 1.8k resistor, we’re feeding roughly 0.21v into the BC558 transistor.
So if we want this to act the same way (at least with voltage), we can put a roughly 140k resistor between 12v and the cutoff potentiometer (where directly it was sourcing straight from 12v) which should feed this potentiometer ~5v, which then makes it act like the 5V CV input.
After that, we can mod the pulldown resistor (heading to ground) on the transistor to be higher so our 5v has more effect. It looks like 4.5k would be good to get us sitting at the 0.21v that the transistor base again.
Any thoughts? Am I completely incorrect here?
