About 4 years ago I made a desktop monosynth based on the layout of the Moog source but I replaced the buttons for the parameters with physical controls. I added PWM and a second LFO for the PWM and a few other features, but it wasn’t great, I had very little idea of how much I could do in software rather than my clunky hardware solutions to detune, octave shift etc.
So now I’m going to rebuild the synth based on the autotune VCOs that I’m using in my latest poly and software LFOs to save space. I’m using the ladder filter design from the Memory Moog, electric Druid Envgen8D for filter and amp, noise 2 for white noise and a couple of AS3340 chips for the VCOs.
All this is going to be built into an M-Audio Axiom M25 case to create a small monosynth. It will be fully programmable and have most of the features of the original Moog Source on the front panel.
The Source based desktop
The Black Pill synth which is the template for the new Moogish synth.
I would love to be this talented one day.
I’m an old fart with a limited skill set working in a country who’s language I don’t understand and constantly being bombed by Russia.
If I can do this I’m sure you can.
Oh now this is exciting. Those maudio axiom m25 shaping to be a good shell for these projects in particular?
Yes I thought I’d grab one before I leave Ukraine, so it might be several weeks or even months before I’m in a position to build anything.
The Black pill synth was mainly a controller and a simple VA synth comprising of 3 parts, but the Moog source style build will be an analogue synth and will require a lot more space for the build. I will actually have to check if I can actually fit the hardware into the chassis. The internal midi board takes up the middle and then you have two spaces either side of about 10-12cm squared, so it’s going to be tight.
Fortunately I can use software LFOs now saving a lot of space and chips. I might even look at software envelopes too to reduce the chip set down even more.
