get a Volca sample, and trigger it from the dtx through midi
*** actually that’s a bad idea unless you can assign pads from the DTX to different midi channels (which the Volca sample needs, as it’s sample per channel design would require)
Someone made a midi cable with firmware that fixes this for the sample, if thats whats desired.
Retrokits RK-002 Smart MIDI Cable, by MyVolts I have one
link => https://www.retrokits.com/shop/rk002
and it’s not just for the Sample, you can load various ‘scripts/firmware’ to change it’s behaviour and connectability to a number of different devices,
I believe that you can program it yourself, but I haven’t investigated that yet!
Where can one purchase this / where can I find more information about this axoloti - eurorack converter?
Scroll through the whole thread since there are a couple versions of Jonas’ board.
Jonas Bers is the creator of the conversion board.
