I’ve been trying to get this Arduino Master Midi clock to work. No luck. I seem to get this same message any time I try to use one of these little displays. Anybody know what may be happening? Master Midi Clock
Have you installed the proper libraries for the displays? You can do this in the arduino IDE.
Sketch -> include library -> manage libraries -> enter ‘SSD1306’ and the Adafruit library will be shown. You can now install it and recompile your code. The error should not occur any more.
so if Arduino’s saying otherwise, that suggests there’s still something wrong with your libraries. Evidently it’s seeing the header file TimerOne.h, but not the library itself.
You need to go over the requirements of the code specified for the midi master code project. Probably its documentation states what libraries you need. There might be a few. But sometimes documentation is incomplete so you are left to sort things out yourself. What is also very important is that you choose the device you want to program accurately. Depending on the device some libraries internally use different code segments because of the differences between the devices. So e.g. if you install a library on an arduino nano that might use different code sections than a wemos D1 in the same library. You may then get error messages compiling for the one device that you will not get with seemingly the same code for the other.
void setup()
pinMode(10, OUTPUT);
Timer1.initialize(500000); // initialize timer1, and set a 1/2 second period
Timer1.pwm(9, 512); // setup pwm on pin 9, 50% duty cycle
Timer1.attachInterrupt(callback); // attaches callback() as a timer overflow interrupt
TimerOne is a class; Timer1 is an instance of TimerOne.
More colloquially TimerOne names a type of object; Timer1 names a particular object of that type.
Timerone is probably undefined. If you have that in your sketch, it should be changed to Timer1. Probably. I mean, depends on what’s in the sketch, but if you haven’t declared Timerone to be an instance of TimerOne, then it probably should be Timer1.
I’m glad I don’t have to try to explain that orally.
I never really learned C of any sort… My general programming tailed off after University and was more linux bash scripting… So there are a lot of concepts I am still fathoming out…
The point is that these are all different kinds of entity. A class in programming is a category to which certain objects belong. In common English, to force a comparison, Police Officer is a category to which certain people belong. You might choose to call a Police Officer by the name Police Officer, and that would be confusing the rank with the identity. And this is exactly what is happening here. The name of the object is close to the class to which it belongs, and you’re right to be confused.
Joe Heller satirised this in Catch-22 by having one of its characters whose surname was Major and whose father named him Major Major Major as a joke. On joining the military the poor fellow is accidentally promoted to the rank of Major. Thus he becomes Major Major Major Major, a burden he finds completely unsuited to his meek temperament.
I strongly recommend you ask some joker on this thread to rewrite the offending code in a way that doesn’t cause such confusion.
