I picked up a cheap Matrix 6 a while back and made some repairs to get it working fully. But it had intermittent boot issues and that bugged me a little. Also I had seen an article from Tauntek about replacing the VFD display with an LCD which intrigued me.
So after contacting Bob at Tauntek he sent me the code and I bought the necessary parts to replace the display. I was being cocky and decided to go for an OLED display instead of the LCD, but it only displayed half of the screen. First 8 chars. Bob was good enough to fix his code to work with an OLED or LCD depending on how you wire a pin high or low.
After then finding the OLED a little on the small side I went with a large 122mm 1601 LCD which fitted the display better.
After this the inverter power was not required to drive the VFD high voltage so I could replace the old linear PSU and transformer with a switch mode. I used an RQ50C +/-12 and +/-5 PSU and it worked perfectly after making a nice connection for it. The Matrix 6 boots perfectly everytime now and has a universal power input.
