Ok, a little explaination, since I use my own ‘well it makes sense to me’ drawing style for this.
Basically all the componants that I will mount to the panel are shown as boxes with the type of componant inside i.e. a box labled ‘Jack’ is a jack socket and is (in this instance) the correct size on the diagram for a Truconnect/Switchcraft style box jack. I have also got an almost phallic symbol denoting a flip switch and a square with a circle inside for a push switch. The arcade buttons and the step controls are arranged into 4x4 grids. I am not showing the arcade switches themselves, just know that the ones I am going to be using are 24mm hole cut out/32mm when mounted with a surround, and the boxes on the diagram are 35mm giving enough space to be sure they will fit neatly when centered in the box.
Ins and outs are labled, as is one of the ‘Step’ boxes, assume all steps are the same, just with different co-ordinate labels (I think I have labeled them wrong on my diagram, but I will double check which way round to properly label my co-ordinates and make sure its right before I engrave the panel). Also, I am using small knobs on the steps, namely the ~12mm Rogan RB Small (no skirt) knobs. They are expensive, but they make everything fit and have a similar style to Sam’s chosen SCI knobs so it should look the part with the rest of my Kosmo modular.
Also I am going with the second possible step layout, so the knobs are in a straight line, as I have also illustrated (in my own rough way) a diaganal variant which likely won’t be used.
The purpose of the Gate switch on each step is to tell the sequencer to fire a variable length gate from the GATE output when that step is selected, the length of which is set via the Gate pot and CV, wheras the X & Y trigger outputs will fire when either the X co-ord or Y co-ord changes. That way I get a nice amount of variation with different kinds of triggers and can generate all three from the Arduino directly. I am also tempted to have them output via a vactrol, to give them more useful shapes if I am using them to ‘ping’ and filter or LPG and it would mean I could easilly bump up the triggers and gates from 5v to 8v to be more euro compatible. The Pattern knob and associated CV input will change the behaviour of the pattern mode (called Snake on the MN Rene), as to which direction it travels across the grid. I may also add toggle switches to allow you to set the X & Y IN jacks to progress either forward or backwards for both inputs (meaning your Y input could be running backwards whilst your X input is running forwards). In Pattern mode clocking either X or Y will produce either a forward or a backward step respectivly along the pattern as selected on the Pattern pot.
Et voila! Hacky ass cartesian sequencing in Kosmo. Here’s hoping she works…
Also is that a dual CV sequencer (like a Buchla 250) or is it a series of AD Envelopes like I am planning?
