probably done before they left China / Hong Kong . make it easier cheaper to ship .
This arrived.
It’s that really cheap dual rail power supply kit from Sourcery. I ordered it a couple of weeks ago in a fit of “worth a shot at that ridiculously low price.”
Edit: adding link to assembly video.
Isn’t Sourcery Kristian Blåsol’s (from MiaW fame) store ?
Yes it is…
I’m sure I read about it here in the power supplies choices thread. Kristian Blåsol was mentioned. I’ll be watching this board with caution. Maybe it’s too full of smoke for my needs, maybe not.
I’m sure it’s fine (I’d prefer some more protection diodes, but otherwise the schematics looks ok if a bit disorganized :smiley:). IIRC from his videos, he’s sourcing components from Elfa (Distrelec) and LCSC, so should be ok quality.
I’ll compare it to the Frequency Central design and see if there’s anything I could add to make it better. For the moment, here’s a photograph of my kit.
The big electrolytic capacitors C5 and C6 are 4700uF 35V. C1 is 220uF 16V, and the other three (C2, C3 and C4) are 1uF 50V.
R1 is there to protect the LED from the 12V RMS AC from the wall wart. The resistor colour code reader app tells me it’s 1Kohm but that’s what it said last time I tried it, on a different resistor.
There are three regulators: 7812, 7912 and (for +5V) 7805. There are three identical diodes: 1N4001.
You also get a quantity of male 2.54mm header, a barrel socket for the wall wart, and a 16-pin keyed box header for Eurorack. There is a space on the circuit board for an on-off switch but no switch is provided so I’ll make a wire bridge instead.
The main difference to the FC will be that they use 3x4700UF per +/-12V which I presume just gives more stable output to the REGS.
There is also plenty of room for heat sinks on the Frequency Central board. As @fredrik has mentioned, this Sourcery board is rather too congested for that. Since a linear regulator works by absorbing unwanted energy (and then dissipating it as heat) that’s a quite important difference.
The regulators sit with their backsides to the edge of the board, so I would think you could mount heat sinks to them, hanging off the edges.
Yeah, it’s his smaller design that has one of them in the middle of the board. This one has the 7805/7812 on one side and the 7912 so while you need at least two heatsinks, you don’t need isolators.
(The 78xx has ground on the tab, the 79xx has the unregulated input there instead, so if you connect a 78xx tab to a 79xx tab, you’ll short the transformer.)
I can’t promise to get this soldered quickly. At the moment the situation is so unstable that I could plug in the soldering iron and get called away urgently before it gets warm enough. I’ll have fun playing with it alongside my Frequency Central board eventually, I’m sure.
Although these supplies nominally give you +5V as well as the +12V and -12V rail to rail I’m not sure that would be better than using the traditional 5V DC wall wart to power my Beaglebone Black/Bela board. For a start, I’m not sure they’re up to supplying the kind of current these small computers draw.
Okay, so as I’ve mentioned, that older gal who has been giving me stuff that she was going to discard otherwise gave me something today that I feel absolutely obligated to offer her some monies for…
It was just sitting in the bottom of one of the boxes she had me pick up today… :open_mouth:
OK, we officially hate you now :laughing:
Well, if you use this properly it will give you tons and tons of insight into electronics. Oh, yes and please refrain from connecting it to the mains power supply until after you have read the manual and have found out which probe you need to do that (if it makes sense at all, just a friendly warning) !
at least with you it will be appreciated and get some use . we still hate / envy you :laughing:
Good for you though.
I have the 1402 in my setup. Owned since new in 1997. Very solid and reliable with more features and tricks than it deserves.
Oh and due to pier pressure and the simple fact of jealousy I hate @d42kn355 too. :frowning: (lucky b…d)
That’s some catch, that Catch-22.
I suppose there’s some overriding reason why the external tab in the 79 series isn’t ground, but it doesn’t seem like a very sensible design choice. I certainly see wisdom in Kristian Blåsol’s board design now. Keep the carapaces far apart.
Sorry, I’m too busy looking at the background location and the fact that you’re standing BEHIND the counter to realize you’ve put an oscilloscope on the counter. :laughing:
