Poor in what way? It’s a PCB for a 100 VA toroidal transformer connected to 115/230 V mains. I guess you could leave out the warnings, but that won’t make the dangers go away.
more power ! that makes a whole bunch now , why do the lights in the house dim when I turn my modular on LOL
They are, so I guess they’re not exactly the same.
Poor may be a bad choice of words @fredrik. It’s one thing to design your own board and through ignorance proceed to burn your house down or blind yourself. But I always feel “iffy” when “it worked for me but may kill stupid folk” hits the hobby market . Like these folks who print plans for 3d guns etc. I just believe you should stand by your work and be prepared to support it.
Not picking a fight with you or metatronics but this is like a kit plane, one cock up and it’s toast. To me that’s not a product it’s a dare.
Chekhov’s 3D Printer.
Exactly @Bitnik ! Kits like this are unfinished professional work and are “unnecessary“ in a DIY world.
Apologies too to @ChristianBloch. Sorry, didn’t mean to poop your purchase mate. Products like that just scare the crap out of me. Play safe.
in reading on these boards [ frequency central FC power ] which I should have done first . the 7812 / 7912 regulators are only rated to 500 ma draw or about 7 / 8 ish modules that pull 60 ma . the 2 amp wallwarts I am using are overkill to . I do have some .47 amp wallwarts wonder if those would be adequate ?
Remember the wall wart needs to supply the total current, if it’s 400 mA on +12 and 300 mA on -12 that’s 700 mA.
Where’s this 500 mA from? ST L7812 is rated to 1.5 A, with adequate heat sink.
muff wiggler forum really old posts probably rev. 1 boards . yeah I was planning on using the 2 amp wallwart anyway just because more head room . I have 16 modules in each rack box and plan on using two of these power supplies per box .in theory that should be fine . I will double check the exact specs of the regulators I am using [ lm7812 and 7912ct ] . thanks for the heads up on the numbers . if we go on about this it will have to be transported to the diy power supply thread
No worries. I personally appreciate the warning, though I didn’t need it. I do find it hilarious.
All in, this build is costing me around $100 whereas a finished build would have been $250. And I’m building two. So far. If I didn’t feel confident I could do it and do it safely, I shouldn’t be saving that money.
I had worked in IT networking for probably 20 years before I discovered the captive nut tool…
Hey Christian…want to build me one when you’re done?
They ain’t much, but they’re mine! Barton Circuits Sallen-Key VCF and Analog Drum PCBs. I didn’t realize how fiddly this was going to be…
I’ll be building one of those filters soon! Putting it behind a Kosmo size panel and moving the middle board mounted pot to the bottom, panel mounted, for larger spacing. And I’ve built the analog drum, too, in Eurorack format.
My plan too!
Assuming I survive, sure
Oh he’s not going to let this go!
10 cheap pots to do the second megadrone, not even finished the 1st!
Oh and got a free new multi meter ( i returned one as it semed faulty, they refunded and sent a free one )
I have this. I love it.
Just a tiny little order from JLCPCB
The Mikrokosmos are up on Tindie. The rest are intended mainly for my use but I’ll sell off leftovers once I’ve checked them out.
