@lookmumnocomputer
What im thinking is that you could have each light configuration be split out into chords, each light triggering a configurable output voltage. Then, you can trigger the envelope with the handheld button to “play” chords while changing the chords up with the little wheel dealie. You’d basically use the light presets as chord presets.
RIGHT! That’s better than what I was suggesting here. Then, you could cycle through each chord with the lever.
