Hi all.
I’m wondering if anyone’s come across a tuner like this thing → LED chaser as a frequency reference (guitars and synths) - YouTube
It works by scanning the LEDs one at a time at 1760Hz (high A) and writing the output of the internal analogue comparator to that LED depending on the state - if the input is positive, the LED turns on, and off if it’s negative.
Here’s the code for an ATMega168P:
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/cpufunc.h>
#include <stdint.h>
#include <stddef.h>
uint8_t led = 0;
void initialize ()
DDRD = 0x7F;
DDRB = 1;
TCCR1B = _BV(WGM12) | _BV(CS10);
TIMSK1 = _BV(OCIE1A);
OCR1A = F_CPU/(440*4);
DIDR1 = _BV(AIN1D);
int main ()
initialize ();
sei ();
while(1);
ISR (TIMER1_COMPA_vect)
if (led == 7)
if (ACSR & _BV(ACO))
PORTB &= ~1;
else
PORTB |= 1;
else
PORTD &= ~(1<<led);
else
PORTD |= 1<<led;
led = (led + 1) & 7;
The LEDs wire to PORTD 0 through 6, except for the 8th LED which wires to PB0. The signal is applied to through a 100k ohm resistor to AIN1 (PD7 or pin 13). I did the LEDs this way because I managed to break pin 15 off my last ATMega (bah!).
The code above will work for ‘A’ across several octaves. Of course, if a switch is added you can select different frequencies to load into OCR1A, say if you want to try it on a guitar.
Cheers.
