Hello smart people,
I’m currently building the Avalanche VCO from Kassutronic:
I’ve built three on my breadboard, and they all work really well. Since I’m only using a 9V battery and don’t need 1V/oct tracking, I’ve only implemented the expo converter.
My problem now is that I want to mix these signals together. However, passive mixing isn’t working. When I put a 100k Ohm resistor on the output, I lose the signal completely, but with 1k Ohm, it works. Still, passive mixing doesn’t work properly.
So, I thought I would buffer the signals, as I have a few LM358 and LM324 lying around. I built three buffers and connected them, but I get no signal at the output. The inputs aren’t affected, as I can still output sound from them, but there’s no signal at either the negative terminal or the output of the LM324 or LM358.
Up until now, I’ve always managed to solve my problems while tinkering, mostly thanks to this forum, but now I’m at a loss.
I know that an op-amp doesn’t work optimally with a single supply, but I haven’t had any problems building buffers with the LM358 or 324 in smaller circuits before. Where is my mistake in thinking?
I hope you can help me.
Thanks in advance this community is awsome!
