A couple of people have asked me to make this post so I’m going to do it. But - right up front…I don’t know what I’m doing. I’ve got a system that seems to be about 98% reliable now…but it took me quite a bit of trial and error despite following a number of great on-line tutorials, videos, blogs and other resources.
I can now go from a print ready design to a finished board in under an hour. The cost per board is a bit tricky for me to nail down since I went down a couple of dead ends in my attempts…but one of the best resources I found calculated a price in 2017 and came up with $0.54 per 70mmx100mm board. Prices have gone up a bit since then though. If you really shot around…maybe you can still get close.
Now - right off the bat there are some limitations here. Be realistic at first. There are people using this method to do really fine pitched SMD parts…but I’m mostly making Yusynth’s boards which have nice thick traces and big clerances…or my own designs which I create with 0.5mm traces and 0.4mm clearances. Though now that I’m having more success I’m thinking about trying some less forgiving specs again.
Also - I’m only doing single sided boards right now. When I design them I do put a few traces on the front side - but those are just to represent jumpers. You CAN do double sided boards and I plan on trying one soon. But it’s a lot more to go wrong so start out easy.
And before I really get into it the other big question is…why? You can get boards professionally made dirt cheap now! I know, I’ve used several services and they’re great! But you don’t want to or can’t wait a week or two or pay high amounts for fast processing/shipping. Maybe you don’t want to deal with selling extra boards or dealing with the guilt of just tossing them in the trash since you usually need to order at least 4-5 boards with those services. Maybe you don’t want to risk good money on a batch of boards if you aren’t sure of the circuit yet (one bad board isn’t a big deal…but it’s no fun to order a run of them and then find a problem!)
Maybe you want to make a board you found art for on the web - but there aren’t any gerbers (like the MFOS and Yusynth boards) so you can’t send it off to a board house. Sometimes you can order them from someone but if they’re out of stock or closed or just not available…the only option is to roll your own. (or design your own board and generate your own gerbers.)
Bottom line, being able to make your own boards isn’t that hard or expensive and can be VERY handy! Don’t be intimidated by it - just give it a go!
A lot of people like the toner transfer method. And I tried this first. It can work. But I’m not a fan. It’s hard to get a really good clean transfer consistently. Even with special purpose bought paper I had a hard time getting consistent results. I have tried using toner transfer for “silkscreen” on one of my boards and had some partial success and will probably try that again. But overall toner transfer is just too iffy of a process even with the expensive special paper.
So I’m using a photolithography process. You can buy pre-sensitized boards but they’re kind of expensive. And I found it’s not that hard to sensitize your own.
Before I go into the gory details of how I do this I’m going to share a link that would have saved me a ton of time and effort if I had found it first: http://www.johncon.com/john/PCB/
That is hands down the best resource I’ve found for DIY PCB’s. He has a ton of great detailed information and details on how he came up with his recommendations. Mine are mostly an echo of his. Anytime I had problems with some step of the process if I tried his methods all my problems went away.
So let’s get into this. There are a few things you’re going to need so let’s get that out of the way first:
The most expensive is an inkjet printer. I tried my laser because I really love laser printers and hate inkjets…but…I just couldn’t get dense enough prints out of my laser. If you have a laser than can give really good dense prints on transparency film (or vellum) - use it! If not…save yourself a lot of heartache and just get the cheapest inkjet you can. I got a Canon Pixma MG2522 for $25 at the local mega mart:
Sitting on top of it is one of the next most expensive things you’ll need. Inkjet Transparency film for screen printing. This is key! I got it off Amazon - 50 sheets for $17 delivered to my door: https://www.amazon.com/dp/B07S5GKGSJ/ref=cm_sw_r_tw_dp_y5mRFbEBGTQDR?_x_encoding=UTF8&psc=1
You can also use vellum - but it’s harder to print on with an inkjet and requires more exposure when you make your board. If desired I’ll do a detailed post later on all the alternatives I tried - but this gave the best results overall.
The other “bit ticket” item is a laminator:
I got this one at the mega mart for $24. There’s an amazon basics one that’s a dollar or two more that’s really popular for this, but it’s smaller. This one isn’t great but it works very well for me. Note - this is technically optional. You could just use an iron. I did a few with an iron and it worked…but it was much easier to get consistent results with the laminator. And at <$25 it’s pretty cheap and kind of nice to have on hand - I laminated a nice cheat sheet on how the CV/Gate outputs from my sequencer map in different modes so it won’t get destroyed
You will also want scissors and tape - but I’m guessing you have those laying around. Note - do NOT use your wife/girlfriend’s fancy sewing scissors as I have pictured here. I’m widowed so I can do these things - but I know I’ll regret it next time I need to cut fabric…I can live with that.
While you’re at the mega mart there are a few other things you’ll want:
Washing soda is what you use to develop the UV sensitive film. Acetone is what I use to degrease my boards before applying the UV film…it can also be used to strip the film after etching the board - but more on that later.
And you can also buy your etchant at the mega mart:
Yep. Just ordinary white vinegar and Hydrogen Peroxide make a functional etchant. You do need to spike it with some salt to get it working well…and it’s a bit slow but it works.
Not pictured but a better choice is HCL - Hydrochloric Acid, sometimes sold as Muratic Acid here in the states. You can find it with pool supplies at most hardware stores or pool stores. It’s pretty cheap. I think I paid $7 for 2 gallons a few years ago when I bought mine. It works MUCH faster than Vinegar - but does fume a bit more so I use it outside.
Also at the mega mart you may want to pick up:
A few containers, a shot glass, and some cheap foam brushes. The bigger container you can just grab from your kitchen…nothing nasty will happen to it. The smaller ones…get something disposable. I use these little ones that my lunch meat comes in.
The shot glass is optional…but it’s the perfect solution to mixing up your etchant. The foam brushes won’t last super long. You’ll need at least two but you can usually get a bag of a bunch of them for a few bucks. It’s worth having spares the process is a bit hard on them.
There are two more specialty items you’ll need both of which you can get off Amazon. The first is the UV film itself. You want “UV Sensitive Dry Film” It’s sold by a lot of places under a variety of names…but it’s suspected that it all comes from just one or two sources. This is the stuff I bought: https://www.amazon.com/dp/B07MMVPY1Z/ref=cm_sw_r_tw_dp_ZfnRFb2GJJ45K?_x_encoding=UTF8&psc=1 That’s a 30cm x 5m roll…it should last a long time.
The other is blank PCBs! These are the ones I’ve mostly been using: https://www.amazon.com/gp/product/B01MCVLDDZ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
They’re only $7 for 10 and are pretty good quality. But…they’re slightly undersized. They measure more like 65mm x 100mm. That’s ok if you’re doing your own boards…but a lot of designs out there are for 70mm x 100mm boards (because that’s the largest size Eagle could do for free for a long time) so if you’re going to try and do some of Yusynths boards his are 75mm x 100mm. For those I’m using these: https://www.amazon.com/gp/product/B07R58VXKT/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 They aren’t quite as nice of boards…but they’ve worked just fine for me so far and at $17 for 15 boards are still pretty cheap.
Ok, unless I forgot something that should be all you need to make your own boards. So I’m going to break this into another post and show my process step by step start to finish to prep and make a board!
It took me much longer to reverse engineer the circuit from Sam’s stripboard layout and draw it in kicad and layout the board than it did to etch the board or assemble it.
