2 modules that I do not recommend, that I built a while ago and are not sastifaisant (for me)
2 on Kristian Blasol’s channel
Buffered mixer : the output volume is infact a gain = big saturation, and a very very loud level out , so it’s an inverter output ( he put in the - of the first op amp and in the + of the second one)
13700 based dual VCA : I put it aside because, there is a big “clic” with each impulse as loud as the sound
I of course have nothing against Kristian, he himself says in some comments that there are problems
and other of this building are good
but it’s always boring to build modules for nothing
I only had to fix it because your wording was ambiguous in English. Your English is good enough for us, and you’re a highly valued poster because of the quality of your comments.
