I ended up going with the T18 shaft pots from Modular Addict, also picked up an AS3340 there and some cool knobs for my project should be here in about a week. If I end up building a lot of synth modules I think I’ll look into getting a larger lot from Aliexpress though.
They’re in stock again at Tayda. They have about 3300.
So about ten minutes worth at the rate Kosmo people work.
By “about 3300” I meant “more than 3300 until they process my order, then less than 3300”.
Current Tayda stock: 6129
https://www.modularaddict.com/ has been dead for days and I don’t want to pay 4/$ a pop on mouser… booooo…
Try @popflier ? ![]()
I have plenty of stock of B100k and B10k pots. I think I have around 200 of each available.
$9 for a pack of 10.
I also have switches and I still have a few brand new 3.5mm patch cables if anyone is in need. Just message me. I’ll ship same day.
Hi, @popflier , I’m new to Discourse and clueless so couldn’t figure out how to message, but I am interested in your B100K pots if you still have some. Reply here or message me, whichever works better for you. Thanks, Dan
It appears that analogoutput is correct. I don’t see the yellow message box, presumably related to my newbie status. I’ll message whenever I’m allowed. Thanks @analogoutput and @popflier for your quick replies.
I got some at Digikey a few weeks ago for $1 each when I bought 100. The downside was that they had some annoying pcb lock tabs, but they twisted off easily with pliers. On they up-side they came in a tray
Hey Dan…I sent you a message. If for some reason you do not receive it then reply here and I can get you my email address.
Hi all, I’ve ran through the same issue for the past 2/3 weeks (UK based). I managed to score some 9mm B100k via modular addict (2 weeks delivery time from the US).
I just ordered some from musikding.de in Germany, it seems like they have some in stock. I used to use them a fair bit when I was building guitar pedals. They’ve been pretty reliable so far.
Hope this helps
Thanks @popflier for braving the snow and getting the pots to me so quickly.
Thonk have restocked for all you UK based people
