trying to locate the WAV TRIGGER box addon LMNC said was over on his Patreon, well I need to locate exactlly where it is and download it. Can anyone help. I am a very large tiier patreon subscriber . Or if someone nicely can send me the link ,it would be most appreciated . I built the BIg Button and had said video but lost it . Thanks in advance
no but I will keep it, thanks for checking Riggidyboo found the older post thanks to both really helps out alot.
bingo winner winner chichen dinner, you saved me alot of work, thanks alot for your help and finding it. Both submissions to me were perfect
so I watched it and SAM never really says where the L and R jacks go yet has a white wrie and purple wire going back to the Wav Trigger and I know where the 16 triggers go but just cant place the white and purple wire connections.
So I think what i see is that the 2 wires white and purple from his L& R jacks go to their proper sides on the wav trigger’s 3.5mm jack , white going to the top left silver tab and purple going the second tab on the right side of that 3.5mm jack. I hope this is right. I slowed and stopped the video many times before Sam swings the wav trigger pcb out of frame.
Yep, and then GND VIN for power by the SD card, and there is a GND on the opposite side
thanks another good eye helping me out, really appreciate this find of a gesture alot . happy Synthing
sam sent me the link on 7/17/25 https://www.you tube.com/watch?V=usCqYkHOY8M
