I’m debating trying out the Cynthcard DIY Controller build:
It looks relatively straightforward. The one thing I can’t figure out is what kind of power I would have to use. The PCB is marked 4V, but aside from that I’m unsure what the smartest option would be. Does anybody have any advice?
Yeah! I had one I used to run MSSIAH on, but it didn’t play as nicely with MIDI, so I ended up scavenged for parts in the end. I have another one that I’m going to try out Cynthcart with. Once I get it working I’ll probably build one of these! If I can figure out the power…
Looking at the Gerber… now that you’ve mentioned it, it looks like it is just the font that made me think it was 4v. At least it wasn’t just me who was confused!!
In that case… I could just wire in a DC jack somehow. I’ll probably build one then. It’ll take me a while as I’ll need to get some bits and pieces, but I’ll report back. I’ll have some spare PCBs + panels too perhaps, due to the minimum ordering numbers.
Okay, I’ve put in my order for the PCB and the parts I need. It’ll take them a while to arrive, and probably longer for me to build the damn thing, but I’ll put progress here. If anybody wants a PCB a bit cheaper and doesn’t want to have to order from HK directly let me know - though if you are outside the UK it might not make sense with postage.
Seriously though, for music the C64 is great. The SID chip was one of the first things I used to make music when I got into electronica. It sounds amazing. It’s just a matter of finding a good way to interact with it, and Cynthcart/this panel seem like one of the better ways. I’ve had Eurorack modules, desktop synths, etc, but they all have their own weird flaws.
The PCB and panel sets arrived and I have a few spare. If anybody wants one rather than going through JCLPCB and their minimum order numbers give me a shout and we can work something out.
I really want to do something for Kosmo with my Sid chip, but it’s quite a doozy to understand the datasheet, hopefully I’ll reach that level at some point.
I also want to do a the c64 build tho lol. Are you in the US? I don’t remember. I’d pick up one of the panel/pcb just in case I eventually do it
As far as building something for Kosmo with the SID…have you looked at the midibox SID? MIDIbox SID
It was the first synth I built. Though I never got more than the patch matrix and LCD with one encoder and a couple of buttons for the control surface before I set it aside because at the time my only MIDI keyboard was USB only and having to patch through the computer was just a pain. And of course a few years ago when I finally got my sequencer working a few days later my SID stopped working and I’ve yet to figure out why
But - it’s a highly flexible design so could be easy to adapt a CS to fit in Kosmo…just a matter of deciding which functions you want controls for. Something like the Sammich SID could easily fit behind a Kosmo panel: sammichsid [MIDIbox]
