Braids THT in KOSMO format
@sebastian - do you have a shop, like an Etsy or BigCartel where you sell your module designs? I want to pick some up!
No, I don’t, but I have published most of my kicad files. I also have some leftover pcbs which I send out. But it usually only is worth it if you’re in Europe, postage to US is usually higher than ordering at JLCPCB… just send me a PM with what you like and I will check what I still have :slight_smile:
I’m interested in putting a JLCPCB order in. I caught aboard the train for KOSMO Braids so there’s a probability of more panels and boards if you’re in US.
Cool! Maybe you could incorporate the tuning switch that Sam proposed? :slight_smile:
Sebastian,
At a later time when I could learn a skill adding a tuning switch between preset and knob potentiometers I could consider. An order from your zipped Gerbers seemed justifiably a job for myself as I’d done the same with your Transistor Ladder Filter.
Okai, then wait a day more and I will add it! :slight_smile: Just need to find out how to add nets in pcbnew (I only have the pcb file and not the schematics file…)
Sebastian,
Okai.
I did a conversion from a eurorack braids using @d42kn355 faceplate but I wouldn’t mind building a second, I’ll pick up a set from you @KardashevTypeII if you print them!
I made the update:
There is a switch now at the right, which connects either the coarse knob or the trimmer. Not sure if the position of the trimmer is okay there, need to check if there is any space on my version and maybe someone has a better name for what the switch does, but that’s it for today :wink:
I’d be interested in a set of these as well.
Sebastian,
Preset
Knob
Sebastian,
The FM and Modulation graphics are such that Coarse is a close neighbor and it was confusing me which knob the graphics were applied.
I would take a set as well.
Yes, you are right, I am open to suggestions again :slight_smile: I did not change the distance between knobs, in x direction there are the headers between the boards which restrict placement and in y direction I did not try… maybe I could try that… :thinking:
I just built 2 of them and it works like a charm! I posted some pictures on FB group!
Cool! Would you mind posting a picture here as well? I don’t have facebook and I am curious how the updated panel turned out with the + and - symbols :slight_smile:
How did placement on the panel turn out? I saw some builds of this and I got curious if the panel has come to a final state.
Hello guys, I have a question : this build requires a lot of 24.9 k resistors, and some 49.9k resistors. I do not have these odd values, all i got is 24k 's and 51k’s … Do you guys think it will be a big issue? I am not really able to tell what are those resistors for, but i understand that odd values in circuits are often important for dividing voltages in a precise way etc… Thank you
I’m also curious about this. Thinking I might risk it.
yeah im going in lol
