I was too late, but on the plus side, I already received them today and they are 128k (at least one of the five-pack ![]()
Excellent. Hopefully the rest also work out for you.
Im in the US, do you have any more 128k blue pills left?
Is there any documentation to add an octave knob to the braids like on the performance VCO’s?
You could use one of these:
https://www.elby-designs.com/webtek/synth-modules/octave/octave.htm
The designs there use SMD components but you could build one on stripboard with through hole parts. Resistors on the switch (R101–R108 in the 5U design, R2-R5 in the 3U) and op amp input and feedback resistors (R110 and R112 or R7 and R9) should be matched at the 0.1% level.
If you don’t need to add a bias voltage you could omit everything downstream of the buffer (U101A or U1A).
Wire the output through a 100k resistor to IC9 pin 13. That resistor should be matched to R54.
I don’t know whether the noise issues are related to replacing the C24 capacitor with a polarized one, but typically non-polarized electrolytic capacitors can be substituted by connecting two polarized capacitors of the same value, i.e. you could join two polarized 10μF by soldering their negative (or positive) leads together and soldering the remaining two leads onto the PCB.
Which results in a capacitance half that of each individual capacitor, i.e. 5 µF in your example, so start with 22 µF if you want to end up at (near) 10 µF.
You’re absolutely right there, that’s what happens when one writes at silly a.m. Two 20μF capacitors are needed, or two 22μF which are more common. I recently had to recap an old preamp that was full of those!
Hey!
In your repository you only have the hex file for the mutated version, right? is that this very advanced bees-in-the-trees firmware? For using your modifications with the “standard” firmware I would need to build the firmware using the source files in your repository?
I would pay good money for the correct blue pill that’s already programmed ![]()
I’ve bought a few Blue Pills and used them in 2 Peaks and 1 Braids (and some experiments) without any problems. Programming them is easy. I’ve found that one out of 7 did not work properly although the MCU ‘accepted’ the firmware. It was not possible for me to tell which will and which won’t, but in my experience, most will work. So I’d suggest you buy a few from different vendors and try your luck.
I’m honestly a bit confused how we ever got the right boards in the first place.
According to ST :
- the STM32F103C8x is 64k,
- the STM32F103CBx is 128k
- but the bluepill board was a 'C8 (64k) part
- and then there was a maple mini boards (and clones) that were CB (128k) but they have totally the wrong pinout. (and the original maple mini boards are also discontinued)
So it seems like the original THT Braids project was predicated on a bluepill clone boards that used the wrong (128k) microcontroller, but those are getting hard to find because ST now charges over $7 for the STM32F103CBx chip, so they’re all using clones of the 'C8 chip.
Maybe it’s time to just start looking at porting the Plaits to THT, since that’s based on an M4 chip instead of an M1, maybe we can get a few more years of development boards out of that.
