Sculpt-O-Sound presents: BluePill-Breakout-O-Matic.
Ever worked with an STM32 BluePill and found it tedious to get it wired up to your breadboard and keep it clear which wire is going where while the BluePill is dangling about? To remedy this I designed a breakout board in order to make experimenting a bit more transparent.
On the board you can find 2 push buttons, 4 LEDs, a rotary encoder and switch, 2 connectors for displays, all of which you can hook up to the BluePill any way you like.
Furthermore, there is a 3.3V and 5V power regulator.
You can find gerbers, a schematic and some more info here.
