Project update: It works! Some hiss at the output but anyways it does do the DSP properly.
Made a simple layout for controlling signal levels, could be improved to reduce hiss.
Here is updated code; changed some pins to make wiring easier, added compressor effect (made with ChatGPT!)
* DSPmega.h
* Created: 2012-10-07 13:04:22
* Author: Anders
*Copyright (c) 2013 Anders Skoog *
*Permission is hereby granted, free of charge, to any person *
*obtaining a copy of this software and associated documentation *
*files (the "Software"), to deal in the Software without *
*restriction, including without limitation the rights to use, *
*copy, modify, merge, publish, distribute, sublicense, and/or sell *
*copies of the Software, and to permit persons to whom the *
*Software is furnished to do so, subject to the following *
*conditions: *
*The above copyright notice and this permission notice shall be *
*included in all copies or substantial portions of the Software. *
*THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, *
*EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES *
*OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND *
*NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT *
*HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, *
*WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING *
*FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR *
*OTHER DEALINGS IN THE SOFTWARE. *
#ifndef F_CPU
#define F_CPU 1600000UL
#endif
#ifndef DSPMEGA_H_
#define DSPMEGA_H_
#include <avr/interrupt.h>
#include <avr/io.h>
#define BUFLENGTH 825
#define BUFP 360
#define BUFPH 150
#define LOWPASS 0x01
#define PITCHUP 0x2
#define PITCHDOWN 0x4
#define BITCRUSH 0x10
#define ECHO 0x20
#define PHASOR 0x80
typedef unsigned char uint8_t;
typedef unsigned int uint16_t;
void ADCSetup();
void PWMSetup();
uint8_t bitcrush(uint8_t sample);
uint8_t echo(uint8_t sample);
uint8_t phasor(uint8_t sample);
uint8_t pitch_down(uint8_t sample);
uint8_t pitch_up(uint8_t sample);
uint8_t lowpass(uint8_t sample);
#endif /* DSPMEGA_H_ */
* DSPmega.c
* Created: 2012-10-07 12:28:13
* Author: Anders Skoog
*conditions: *
#include "DSPmega.h"
volatile uint8_t effects= 0;
int main(void)
ADCSetup();
PWMSetup();
buttonSetup();
while(1)
if (PINB & (1<<PB6)){
effects&= ~PITCHUP;
}else{
effects|=PITCHUP;
if (PINB & (1<<PB7)){
effects&= ~PITCHDOWN;
}else{
effects|=PITCHDOWN;
if (PIND & (1<<PD6)){
effects&= ~BITCRUSH;
}else{
effects|=BITCRUSH;
if (PIND & (1<<PD7)){
effects&= ~ECHO;
}else{
effects|=ECHO;
if (PINB & (1<<PB0)){
effects&= ~PHASOR;
}else{
effects|=PHASOR;
if (PINB & (1<<PB1)){
effects&= ~LOWPASS;
}else{
effects|=LOWPASS;
void ADCSetup(){
ADCSRA |= (1<<ADATE)|(1<<ADIE)|(1<<ADPS2)|(1<<ADPS0); //freerunning ADC, prescale 64, samplerate 19230Hz
ADMUX |= (1<<MUX2)|(1<<MUX0)|(1 << ADLAR)|(1<<REFS0); //ADC5 (PC5) , 8bit adc, Vcc ref
ADCSRA |= (1 << ADEN)|(1 << ADSC); //enable ADC, enable interrupt
sei();
void PWMSetup(){
DDRD |= 1<<PD5; //output PD5
TCCR0A |= (1<<WGM00)|(1<<WGM01); // select fast pwm mode 3
TCCR0A |= (1<<COM0B1); //Clear OC0B on Compare Match, set OCR0B at BOTTOM (non-inverting mode)
OCR0B = 128; //duty cycle
TCCR0B |= (1<<CS00);
void buttonSetup(){
//pull up resistors
PORTB |= (1<<PB6)|(1<<PB7)|(1<<PB1)|(1<<PB0);
PORTD |= (1<<PD6)|(1<<PD7);
uint8_t bitcrush(uint8_t sample){
sample=sample>>6;
sample=sample<<6;
return sample;
uint8_t echo(uint8_t sample){
static uint16_t indexWrite=0;
static uint16_t indexRead=1;
uint16_t temp=0;
static uint8_t Buffer[BUFLENGTH]={0};
static uint8_t downSample=1; //
temp=sample + (Buffer[indexRead]>>1); //Reads sample and adds echo
Buffer[indexWrite]=(uint8_t)temp;
if (downSample==1)
indexRead++;
if (indexRead==(BUFLENGTH-1)) indexRead=0;
indexWrite++;
if (indexWrite==(BUFLENGTH-1)) indexWrite=0;
downSample=0;
}else{
downSample=1;
return (uint8_t)temp;
uint8_t phasor(uint8_t sample){
static uint8_t Buffer[BUFPH]={0};
static uint16_t temp=0;
temp=(sample>>1)+(Buffer[indexRead]>>1); //Reads sample and adds flanger
Buffer[indexWrite]=sample;
indexRead++;
if (indexRead>=BUFPH-1) indexRead=0;
indexWrite++;
if (indexWrite>=BUFPH) indexWrite=0;
uint8_t lowpass(uint8_t sample){
static uint8_t filter[9]={0};
filter[8]=filter[7];
filter[7]=filter[6];
filter[6]=filter[5];
filter[5]=filter[4];
filter[4]=filter[3];
filter[3]=filter[2];
filter[2]=filter[1];
filter[1]=filter[0];
filter[0]=sample;
sample = (filter[0]*0 +filter[1]*0 + filter[2]*22 + filter[3]*75 +filter[4]*108 +filter[5]*75 + filter[6]*22 + filter[7]*0 + filter[8]*0)>>8; //fir order 7, window Kaiser (beta 2.5, fc 3000Hz)
return sample;
uint8_t pitch_up(uint8_t sample){
static int indexWrite=0;
static int indexRead=1;
static uint8_t Buffer[BUFP]={0};
indexRead+=2;
if (indexRead>=(BUFP-1)) indexRead=0;
indexWrite++;
if (indexWrite>=(BUFP-1)) indexWrite=0;
return Buffer[indexRead];
uint8_t pitch_down(uint8_t sample){
static uint8_t half=0;
half++;
if(half==2){
indexRead++;
half=0;
indexWrite++;
ISR(ADC_vect)
uint8_t ADCdata=0;
ADCdata=ADCH;
if(effects&PITCHUP) ADCdata=pitch_up(ADCdata);
if(effects&PITCHDOWN) ADCdata=pitch_down(ADCdata);
if(effects&BITCRUSH) ADCdata=bitcrush(ADCdata);
//only echo or phasor can be used at one time
if(effects&ECHO)ADCdata=echo(ADCdata);
if( effects&PHASOR) ADCdata=phasor(ADCdata);
if(effects&LOWPASS) ADCdata=lowpass(ADCdata); //clean up the signal
OCR0B = ADCdata;
If I ever return to this project I might try to add clipping indicator and different effects with controls (as there are unused ADCs on the chip). Would be great to get some airwindows vst code working, some of them are such simple that they should run well.
