This pick is slightly incomplete. It’s only missing the final output mix. I put mine through a simple opamp mixer, but you could just use as is with the resistors. Also, I advise sending a single cv (from a single source) input to pin 5 of each monostable timer ( the two 555s on the right). You can add as many secondary timers as you want with an opamp mixer…
Here’s the instructable if you want a tutorial on a point to point version.
I love the idea of making a megadrone version!
Can Sam or anyone rise to the challenge of an APC with at least 100 monostables, maybe even 1000 or more. 555s can be gotten very cheaply from China .
You would clearly make a system with 555 of them. I mean, OBVIOUSLY.
I thought about doing one with 3 monos but it has so much sound already with just the 2! This is my new favorite module.
Id like to try mixing the sawtooth signals across each monostables timing caps, that might be a bit more subtle also could add some filtering in the signal mixer
@mightywombat : 555 monostables, YES of course!
