I was talking about it a bit on the discord server but Caustic told me to create a thread so here we go.
I have been interested in modulars since discovering LMNC but I dont have the budget to start a modular rig currently so I thought I would do a simpler project, everyone likes the NE555 and I have a 3d printer so I figured I would give a keyboard a try.
I started by ordering some parts and since that would take about 2 weeks to arrive I started designing the actual printed parts for the keyboard, I had pink loaded in the printer because I made some stuff for pink october here so I used that and that earned the keyboard the nickname “Pink Panther”
The keys are printed as one, it relies on a flexible plastic hinge for the movement and it has holes to center the “black” keys over it.
I also designed the keys to be on the wide side so it could be easily playable while wearing a fursuit, this is also sort of a prototype for a future project.
The actual electronics of the keyboard is just a line of switches and 2.2k resistors arranged like a big voltage divider.
I picked 2.2k because I had some of those and it would work ok with the capacitors I have to tune it.
The design is quite simple, just the good old astable 555 stuff where the keyboard is R2 and I will use a trimmer pot as R1 to tune it, I might have to use another trimmer to make both ends in tune tho.
Today I received the electronics I ordered so I started breadboarding, after a long time of chasing very simple mistake I got it buzzing.
I tried using 2 NE555 in parallel to make it sound fatter, they share the same “tuner section” as I like to call it and they go to the speaker through capacitors for decoupling but it gets kinda weird then.
As you can see in the graph, the waveform is pretty weird.
Single 555 waveform for comparison
I dont know if it is an issue or how to fix it, Caustic suggested a buffered mixer so I think I will do that and I will probably give oscillator its own filter before going into the mixer (it does sound cooler than a single 555 tho)
Anyways that is all I have for now, im sure I will receive plenty of good advice here so im not worrying too much.
If it turns out well I will probably publish the 3d files and schematics.
), giant floor stomp pads…
me too it reminds me of good memories, long life at 555
