So I was working along with the builder live stream, I hope it’s ok to post about it.
I was having a bit of trouble with each of the pots making a real difference to the sound, then I found another schematic that adds a LFO to the original Atari Punk Console: http://lushprojects.com/vpc/use/
Which seemed to work pretty good!
I then added the other side of the 556 into the first 556 like in the live builder stream.
I also wanted to add a third 556. But when adding a new chip, even when there isn’t a direct connection to the other chips, apart from 9v and ground, it changes the sound. I’m not sure why.
I tried adding some diodes but I’m not really sure what I’m doing. I’ve been mostly trying out different connections and seeing what sounds better, no electrical theory unfortunately.
Here is a video of my test:
Does anybody know why the chips interfere or how it could be fixed?
I made several and it is simple to build and also to modify (16 step instead of 8, switch on / off on each step, LFO, add external clock, reset button, add aMS20 filter, delay2399 …)
if you want some schem or help …
I’m more wondering why adding a third chip to power and ground affects the output sound of the other chip without them being connected in any other way
250mA I think it should be able to power your circuit normally.
have you tried with a 555 as the third (for the LFO)? because only half of the 556 is used for the LFO, and maybe some pin should not be floating and connected to the GND ? (and will consume 2 times less)
Input is how much current it may draw from mains, but since you can change the output voltage they just give the max power (30 W) and the actual max amps depends on the voltage (30 W at 9 V is over 3 A, which is enough for a lot of 555s…)
I split out the LFO to a 555 chip then ran that into the second 556, both sides, and then into the punk console. Also added a power decoupling thing like the link showed.
I think it works better but I have no idea if it should sound better or work better than it does. I might try a few different capacitor values on the second 556.
