Any thoughts on what this is, strange
I picked up ~10 of these boxes from a local auction room.
The auction porter said they came from a lady who did horse physio.
I can’t think how or what they would be used for. there’s a pair of banana jacks on each end which I assume just daisy chanis each module with a DC supply and ground , or AC? … The a select switch and a bunch of pots per row. The metal pads are connected and are aluminum.
I have no clue!
and how would a horse interact with it?
:horse: :stethoscope: ?
there are 13 black ones and a further 2 in IP65 cases… All more or less the same.
selector switch slects a pad per row and the pot feeds the pad .
I was half excpecting nothing in there other than unwired pots, someone was sold some SHAM healing device…
I was half expecting somethign very interesting.
That leave 0% of me expecting this?
There’s got to be an equestrian-adjacent subreddit that might know.
Obviously I am not going to use it for it’s intended purpuous, so not overly fussed. But my curiosity is peaked. I can only think that it provides high frequency AC and the user would rouch the pad whilst grounding to the horse to stimulate musscles ( no not the aquatic ones ).
@lookmumnocomputer , if you think you can adapt these into something , it’s minimal work on the construction side, I can box some up and fire them downto Kent.
A horse organ :wink: to join the owls.
These would make a great base for matrix mixers.
You can easily hook an arduino to them, re(configure) the pads and potentiometers as inputs, and use the as midi controllers.
buy it then
