I bought an Akai LPK25 controller keyboard a few years back for uni, and have rediscovered it. I know there won’t be much I can do with it as is, unless I wanted to go down computer audio and that kind of thing (which I was traumatized with from Uni, hence no longer using it) and I was thinking in my (not so) infinite wisdom that I could take the guts out it, and make…something?
Any ideas or experience with repurposing effectively “toy” keyboards I’d be much obliged!
Could be easiest to keep it as a midi controller, then build it in to a custom case where it controls an Arduino or Pi powered synth. There’s a few minidexed builds like that.
Or you could add some functionality, maybe midi to cv outs, custom case, and then use it to control a modular?
If so, I think you might need a midi host - they can power a class compliant usb midi device and ‘host’ it in place of the computer, then they convert signals to midi out.
There are diy Arduino builds about, or you can buy them. I purchased a cheap doremidi box second hand that works well as a conduit between my CDP S100 and my synths.
I was in a similar situation with the Akai MPK Mini and really couldn’t decide what to do with it, until fortune blessed me with an MPC One and a firmware update added USB midi support to it. It’s complete overkill to use it as a £600, 2 kg adaptor for USB midi to CV/Gate… but it’s curiously satisfying and, let’s face it, a ridiculous flex
So it turns out this board was also used for the ION ICK02 controller keyboard. Not sure what (if any) differences there are between the two, just a nifty bit of trivia
I bought one of these two, not knowing there was the (ARRRGH!) USB-MIDI ports. Even though I must try to put all pieces together and donate the thing to my son, I wondered if the keyboard could be used to produce a 1V/oct signal and gate.
But I will glew and screw it togehter and send it off.
(I also have a SubZero Control Key 49S with REAL MIDI and unreal USB MIDI)
