A796HC equivalent
Hey anyone know of an equivalent to the A796HC that is used in the ring modulator of the Yamaha cs-50 and 80? I wanted to attempt to make a ring modulator form it
Not to be off topic but, hey, why did you make a separate account? @Jewceman @Jewceman1
So apparently with my old account I changed the password because I forgot it at some point and I forgot what it was exactly that I screwed up with, I know it was some kind of authentication, like I think either a save key, two factor authentication, or something because I forgot. But what ended up happening is that I screwed up so bad that I was locked out of my own account for months now
Take a look at the MC1496, maybe it will do similar things.
Ok, I can help you recover your account and join things up if you want.
