A litany of dumbassery
  • for x in range(1, 100000000):
    • print(" :+1: :love_you_gesture: :+1:")
I just ran it to see if I could get an error code but I just went into the singleplayer and lo and behold it’s playing nicely now.
Sorted. Now I can play minecraft instead of music!
650+ items ordered from Tayda. Not one of which is a 10 pin box header. :frowning:
yep did a "good " one even after reading about d42kn355’s miss fortune of plugging the power into the link socket on the 1222 VCO , I managed to do the same on the 1 module out of 3 that hadn’t put tape over the link socket . luckily it was a quick matter of changing the tl074 ic out and taping over the link socket . plugged it in right and it seems to work . well they light up , haven’t checked for sound or tuned yet. moral of the story kids is that is a good idea to plug / cover the link socket when not in use .
2 mm isn’t that big a mechanical discrepancy, right?
(Good news: found in KiCad, not in hardware. I’d uploaded the Gerbers but not yet pressed “order”.)
Forgot to let space for the rail — again!! :-/
Spot the problem:
One more for the checklist :grinning: (but luckily, the PCB could at least be used for testing, after some minor tweaks. And with fewer clamping diodes…)
Who let the smoke out!?! Poof! Poof!
Unfortunately no smoke, the power supply I used for testing is too polite :grinning:
Root cause was a weird TL072 schematics footprint in EasyEDA, with VCC− at the top (checked my other EasyEDA PCBs and they’re all fine, so just bad luck/memory and I should use my own footprints…).
Unfortunately?
(%@#! minimum character count)
Yay I would have gotten it right if I’d have been brave or timely enough to guess. As far as the circuit goes, Is the circuitry leading to the inverting and non-inverting inputs assuming the reversal?
@antoine.pasde2 Unfortunately, as in “lack of entertainment value” :grinning:
@Maxhirez The circuit was fine, it was just the power rails to the TL072 that were backwards. Usually, you want your + to point upwards and your − to point downwards, but that was apparently too easy for whoever added this footprint. And of course I didn’t check that part against the datasheet…
Ive seen it both ways, i guess its just something to watch out for. Ive looked around for conventions, but i dont think (at least from where ive been looking) that there is a general rule for that. Ive even seen inverting op-amp circuits with the positive on top.
The problem is power, not inputs. +12V pointing down is just silly. It’s like north and south on a map, you don’t flip the directions around just like that.
But yeah, the point is that you cannot trust the EasyEDA footprints. I had an issue earlier where some genius had decided that the line on a 1N400x represented the anode…
so I ordered an other mini ADSR thinking I needed one , there is a space in my rack where there should be one . well as I was digging around my bench last night a came across the ADSR boards and chip still in the bag , apparently I already had the missing ADSR just hadn’t put it together its been so long sense I had ordered the 10k pots [ 2 months] that I forgot I had it .
Yeah, you’ll use both.
yes most defiantly .
Well my sequencer design has a major design flaw on the original version of the PCB delivered the other day.
I inadvertently chose a digital MUX for the analog inputs, even worse i just used the same one for the Digital outputs, even worse the correct units are not pin compatible…
Bo xxxxx.
After discovering the above i searched and orderd some 4051’s … like the ones i ordered a month ago!
The secret of electronics is that everything runs on smoke. If you let the smoke out your circuit will stop working. Keep the smoke from escaping!
