It depends on your supply voltage – if it’s good enough to give you ~11.5 V or above, you can use 270 ohm and save a tiny bit of power. If it may drop below that, you may have to use a lower value to make sure the TL431 gets the 1 mA it needs to regulate. See discussion in this thread:
