One resistor less than the number of steps.
(On the picture there are 11 resistors for 12 steps, and 5 Rs for 6 steps)
The Rs value doesn’t matter much, anything from 1K to 10K should be OK.
Just be sure they are all the same so you get equal steps.
Someone else asked about how to calculate the resistor values over here:
It works!
I connected the pot output to an LED and it works as a voltage divider!
Now I’m struggling to write the Arduino script, do you know that language?
I have downloaded this script from the internet. It is based on an example that uses rotary switches.
I can kind of get what it does, but I can’t get it to output the rotary position.
No, that’s not good, it connected each pin of the switch to a digital input of the arduino (the first 4 as it only uses four steps).
You should connect the middle pin (pin A) to an analog input and read it as an analog value.
Something like this :
