That’ll let through maybe 8 µA? That’s still a lot of electrons (4.993×10¹³ per second, to be somewhat precise ), so will probably generate at least a little light, but maybe not enough to be visible outside a dark room. I would recommend adding a simple opamp buffer to prevent the inherently non-linear LED circuitry from interfering with the CV voltages.
If I followed you up correctly this is what came in my mind (I’m not sure how well the “1v/oct osc” is represented by just grounding the resistor that should follow the circuit). https://tinyurl.com/y9zoe63a
Sadly I don’t have an op amp to try right now but I’m waiting an order and I could spare one to experiment with hehe
