I’m building a “half century” of 50 “Super Simple Oscillators” and I’ve read though the other threads on issues and problems with it (I discovered on my own that the transistor in the schematic was backwards but that’s an important find!) but I still have two questions:
The LED does not actually do anything to the sound itself, correct? It’s just a pretty light as far as the circuit is concerned if I understand correctly. In my breadboarded versions nothings sounds very different even without the LED in the circuit.
Loading: I presume there is a drop in signal is when attaching two oscillators’ output together. Then a similar drop with 4 oscillators, then 8, 16, 32, and 64. For the complete instrument that might not be intolerable, but it also might be better to have a buffer of some sort. Or are most people just putting all the oscillators together on the same bus and going into an amplifier from there?
It’s drawn from the bottom. Emitter towards plus (see here).
Well, it shows that the oscillator is oscillating. If the transistor doesn’t do anything, it won’t light up.
You can add a simple summing mixer, see e.g. here for a 6-input mixer that you can expand to any number of inputs (mute switches and potentiometers are optional, the 100k summing resistors are required).
The LED isn’t needed to make the oscillator work, but it does drop some voltage so affects the oscillator pitch, I believe. You can try breadboarding with and without the LED to see what the effect is.
More experiments. I thought the oscilloscope was in frame but um. Not so much. Sorry about that. Trying out mylar vs electrolytic capacitors. Gnomus Half-Century avalanche part II - YouTube
What @dud is demonstrating is that if you put the URL for the video
on_a_line_by_itself
then the forum software will embed the video in the post, so you don’t have to click away to YouTube to watch it. (Similarly, in many cases a link to a web site on a line by itself will turn into an embedded preview of that site.)
Thanks!
I tried putting a resistor before the LED’s (I think one of them has a 1k still on it) but it doesn’t seem to make much difference – the voltage at the LED is about 3 volts no matter what I do (well, no, it’s lower with a resistor in front of it so what I mean is that as long as it’s below 5? volts I think I’m safe.)
Most of the LED’s are only driven by one of the 5 oscillators in a given column. But some are driven by all of the oscillators. I haven’t burned out any LED’s yet.
