I found one mistake, on the simulation, on a resistor value on the resonance path. Not sure if this was spotted before.
The 1M to ground is set to 1m, so 0.001R I guess. (thanks (@analogoutput )
Seems to be working here (more or less) : https://tinyurl.com/2dxljq2d
I changed few values here and there. (to me) It looks like the numerous capacitors are making the simulation tricky.
I played around with the circuit a bit and got the impression that the range of the CUT OFF pot was too large (in extreme setting the filter dampened the input signal completely but also output a slowly decaying DC voltage). For this I changed the resistor values for CUT OFF a bit. I left the rest of the circuit untouched (see pic below). Note: setting T1 and T2 is crucial. When using the modified circuit and setting T2 in the mid position and T1 at about 90% reducing the range of the voltage CUT OFF can be set to in the simulation gives a nice range of low attenuation to full attenuation of the signal (as a LF filter). The resonance pot also has a nice effect.
