Hey gang.
I’ve got five sets of Eurorack through-hole Braids PCBs. I’m not going to want all of them, so I was thinking about selling spares on. There’s a bunch of ICs and the LED displays that are just a little bit harder to source than the likes of TL074; I’ve got some of them as well (only three of each of the voltage reference ICs at the moment, sadly) and I’m going to order the ADC and DAC ICs in the next couple of days.
My question is, would anyone be interested in partial kits? You’d have to bring your own BluePill board and common components (resistors, pots, jacks etc) but I’d be looking at bundling together:
- both Sound Force PCBs
- the Eurorack front panel PCB that Sound Force linked to (I’m not keen on it but it’s serviceable and if you’re using Kosmo format you’ll be doing your own anyway)
- two of the 2x14 segment LED displays in red
- MCP4822 DAC
- MCP3204 ADC
- (hopefully) LM4040 2.5V and 10V reference regulators
- (if needed) MCP6004 opamp
- (if needed) rotary encoder
I’m assuming that the other ICs are part of everybody’s arsenal: TL074, TL072, 74HC595, 3.3V regulator for the BluePill. I have all these knocking around but I can’t vouch for the quality and authenticity of these particular components so don’t want to bundle them in. The ones listed are from one of RS, Farnell or Mouser.
PCBs are JLCPCB cheap-n-cheerful ones, so they’re 1.6mm (including the front panel) and probably have lead in the HASL finish (yes, including the front panel. We’re all going to die, anyway.)
No BluePill, no jacks, no pots, no caps, no diodes, no resistors, no headers, no warranties. It’s a bundle of useful bits, not a kit of parts
you’d be in the same situation as me, working your way through what documentation is available.
All that being said, is anyone interested? I’m not looking to make a fortune off this, just covering costs. I’ll work out exactly what those costs will be if there’s any takers. I’m in the UK so postage will vary based on where in the world you are (and you might be able to assemble the bits locally far cheaper than here on Brexit Island).
