Nice! I’m a big fan of foamcore and have done a bunch of projects with it. I even designed an improved needle cutter and build a MPCNC specifically for working with it. I actually redesigned and upgraded the needle cutter again after that: https://www.thingiverse.com/thing:2450613 I need to do it again to update it to fit the latest version of the MPCNC…but I’ve been lazy about upgrading my MPCNC. I really want to…but…it works. So I hate to tear it apart just to upgrade it
This is one of the fancier things I designed and built out of foamcore, a little rack for ink samples:
Once nice trick I found - leaving a flap of paper off the edge that you can then wrap around the edge to finish it cleanly:
I also made these sun viewers for the eclipse in 2017:
They were a big hit with my daughters school class
I mostly use the super cheap foam from the dollar store. I’ve used some fancier foam but find I like the versatility of the cheap stuff better.
I’ve also done a number of experiments with laminating it for extra strength. I was trying to come up with a cheap material for a shrouded quadcopter I designed:
The ply was beautiful…but not nearly strong enough and didn’t survive even mild crashes
Carbon Fiber would be great…but is nasty to cut and sheets big enough to cut this out of are crazy expensive and most of it would just go to waste.
Laminating with the cheap fiberglass you can get a walmart gives it a LOT more strength…but makes it a lot heavier. And the polyester resin they sell will melt the foam so you have to use good epoxy instead. But if you’re not worried about weight it’s cheap and makes for some VERY strong material.
I got some more expensive but much lighter fiberglass (0.56oz and 1.5oz and was getting some very promising results:
I also experimented with using “red rosin paper” from the hardware store. It’s $13 for a 3’ by 160ft roll so pretty cheap…but works really well as a laminating material on foam if you’re not worried about weight.
The big trick to doing good laminations is to use peel ply. Just cheap polyester fabric (i.e. suit lining - get the cheapest you can find) since the epoxy won’t stick to it - but will wick through it. So basically you have foam - laminate/epoxy - peel ply - layers of paper towels. And then weight it down. The excess epoxy will wick through the peel ply and into the paper towels leaving you with a nice smooth clean laminate that doesn’t have excess resin in it.
Might be worth trying if you need some extra strength in your build!
