About to attempt some SMD soldering. Any recommendations on a good tip for my soldering iron?
I wasn’t brave enough to try SMDs with my iron and went straight to hot air after some recommendations from friends in the know. Have you considered that option?
I have. I am also considering the paste & cook method.
The hot air station seems like a bit of an extravagance for something I don’t plan on using terribly often.
I hear you, I felt the same way. I picked up a cheap-ish one (70€), and watching components pulled into place by the surface tension magic in the solder paste when it hits the right temperature was worth it.
Hmmm reminds me of the psp led mods I used to do. Bloody tiny things.
Just tin one pad and line that up, nice n flush.
Then use some flux and rake over the rest of the pads.
Or use stencils and paste =)
Good luck =D
