I have made a couple of LMNCs modules and have all been cool
I am making the Simple Envelope and just had a question about the potentiometer ground.
I though that pin 1 on the pot (as looking from the front was ground) but it appears in the diagram for this that Pins 2-3 are connected to ground? Unless I am missing what he means when he says the Pots are viewed from the front? Also I might be missing entirely how pots work - so like I said be gentle with me!!
I did put this all together and the LED lit up but it did not seem to do any enveloping?
So just thought I would make sure I have not wired the post wrong first of all.
So in the diagram the connections with the pink wires to 2-3 on each pot - look like they go the the 1uf capacitor which in turns is tracked to the ground?
Or am I reading the pot the wrong way and they are pins 1-2 that go to ground?
Once agin sorry for my lack of knowledge
And thanks for the nit with the 10k - I replaced one as LMNC advises but did not do the others - I will try that today.
hey ! pelagos are you using A1m potentiometerss or B1m potentiometers?
A1M have a l;ogarithmic curve to them and it could possibly explain why your noticing them being all of a sudden loads of attack. have a look at the writing on the potentiometer if A1M definitely have a look at finding some B1M B potentiometers have a linear curve
With the pot turned right down (counter clockwise) I get the envelope and then if I turn it up a couple of percent the signal just drops completely…
I was running the gate out from my SQ-1. I tried it out the CV out that you can change the voltage from 1v up to 5v out. At 5V the attack certainly responds better - but still only up till about 50% then it stops again. Maybe the gate out from tech SQ-1 is not strong enough?
Thanks for any advise and appreciate the time taken to advise!
try bypassing the diode? if not sure just twist it so both metal bits touch so you can see what happens haha the diode does cause a voltage drop I have found some none modular things dont give enough voltage to trigger this so yeah give that a go
