Proprietary DMX Circuitry
I feel like I am getting a good grasp of the basics of DMX and I have a pretty basic system up and running. Now I am trying to figure out how to work with these:
It is a group of 8x8 mirrored floor tiles. They are connected in columns of 8 and each column goes to a control box.
They have 8 dmx channels - a master fade, red, green, blue, strobe, speed, and a “program” channel that can run custom programs.
The manual is pretty sparse and the build quality dubious at best. Currently I have all of my DMX controls running through QLC+ on a laptop. I can control the entire floor as a single entity but discreet control over individual tiles is eluding me - which is unfortunately exactly what I need to do!
I’m sure it can be done - the pre loaded animations certainly can. The proprietary software that I found for it that they use to make animations is convoluted and apparently requires Solidworks (which I dont have). I dont suppose anyone would be able to help me to hack these a bit?
You’d need to set each to a different starting channel. I suppose there is some dipswitch or button to change the channel?
Sounds plausible,
@zorch what do you mean by the inbuilt animations?
Link to the manual?
i would create a new fixture in QLC+ once i understood the unit. makes life much easier,.
I’m not sure how well things will send through here - but I uploaded pretty much everything that I have scraped together all in one place. I made a QLC fixture, created a mockup of the menu system on the control box, and uploaded all of the software that came with it.
https://drive.google.com/drive/folders/1_jyCTvlhlZXLhLW7OlNPzz8ANNuAE5eL?usp=sharing
The “program” channel cycles through all of the pre built animations (in the mysterious .fsd format). There are 65 of them.
I think this PDF -
Is attempting to explain how to generate new animations, but I have yet to make it past AUTOCAD portion of the instructions.
The object is to get light arrangements like this:
I’ve rotated the orientation of the floor to reflect how it is installed - the wires have to come out of the “bottom” edge since it butts up against walls on the other sides.
Told ya! It is all done with mirros (and smoke).
wow that’s over complex… Never heard of using autocad for lighting and how many people use or have access to it??
I suspect most users of this product go for Sound-To-Light and let it do it’s own thing…
Looks like a profuct where “Somebody Loves It” and only they have a clue.
Would there be any harm in taking one of the mini-xlr cables (that go to the control box), run it through an adapter and then plug it into a DMX control console?
I would suspect the boxes are just serial addressable LED’s . You would have to understand that and then build a DMX to adressable driver ( not hard ) I would imagine your going to run out of channels quikly if each LED is 3 chanels it only allows for 170 “Pixels”. But without any details on the product it’s a bit difficult.
