I bought this lovely old dual linear supply at local Anchor Electronics for $15 today. Does anyone know what the S and S RTN pins on each rail is for? I was thinking switch, but it works without anything connected to them and puts out just a few mV less than the OUT pins on the S pins.
Found a datasheet on Mouser:
https://www.mouser.com/datasheet/2/373/sl%20power_linears_ds-1203574.pdf
But…doesn’t explain pinouts. It does say they have remote sensing. So I’m guessing it’s related to that.
Richard Brewster just had a blog that he had to replace the old caps and such, you could look him up thats the exact supply he uses in his massive synth rack . He is a pugix.com, that might help hopefully, I go to Anchor alot hope we run into each other soon or someday.
S is 4-wire remote sensing, i.e. using separate low-amperage (low voltage drop) wires to measure the voltage at the consumption site, to compensate for losses in the higher-amperage supply wires:
(from here).
That drawing uses S+/S− for +/− but for your bipolar supply I assume you want S+/S+ RTN for the positive rail and COM, and S−/S− RTN for the negative and COM. Well, if you bother with this; not sure it’s that useful for synth supplies.
(seems Condor just threw in the towel, btw)
Yeah, seems like he just leaves them disconnected.
Thanks, that makes sense. Sad about Condor.
