The results are in, but they are not overwhelming in this case.
I’ve tried to replicate the lighting situation as close as possible when making the pictures shown below.
These are the keys before applying peroxide:
These are the keys after the procedure:
I can see some but not much differences, but I must say:
1: I’m not a photographer, so the light or my phone’s camera may be playing tricks on me here.
2: there was not a lot of sunlight the last few days
3: I do not know anything about the quality of the peroxide-gel I was using. Maybe the gel is not suited for this use case.
4: I used an ordinary transparent plastic bag to put the keys in. I have no idea about whether enough UV-light passes through this plastic bag.
5: I have no idea how the result of the procedure can be expected to vary with the type of plastic involved.
6: I have no idea how much peroxide has to be applied, how often and how long it needs to be exposed to how much UV-light.
Yep, there are a lot of variables involved and no doubt I forgot a few here.
From remembering the keys when I first saw them to when I see them now, I still have the idea that they are distinctly more white than they were. When I look at the non treated side of the keys and compare that to the treated side, there is a more distinct difference in color.
This is for people who are new to keyboards (the rest of you can skip this): to the left you see the bottom side of some of the keys, to the right you can see the top side of some keys
The bottom side of the keys on the LHS show the kind of ‘yellow’ I remember from seeing them the 1st time.
In conclusion for this experiment I would say that the results are only vaguely positive. But given there are a lot of variables and a lot of unknowns, I would not dismiss the procedure.
Furthermore, to contrast this result below you see a picture of a sensor of a weather station I treated in the same way. Here the colour change between the plastic before treatment (right hand side) and after the treatment (left hand side) is more apparent (althought the light in the picture is different). I treated the plastic 3 times with the peroxide-gel and it was exposed to sunlight (well it was mostly overcast) for 3 days.
I used the same gel, the same plastic bag to enclose the sensor in while it was exposed to sunlight. But this may be a completely different material to start with, so …
All in all, you mileage may vary when trying this.
