I’ve also had my eye on this one which uses 3xLM358 op-amps to generate triangles:
Only issue is that it’s at 9v, don’t know what will happen it if I power it with 12…
Pop it between Eurorack 0V and +12V rails and see what comes out.
Add two resistors as a voltage divider to reduce the voltage to 9v. One between gnd and the 9v trace and the other between the 9v trace and the +12v wire. Sorry, I’m too medicated to do the maths so jfdi badge to the first with values
The design I’m working on only needs TL082 and transistors, but the 1V/oct input only works for 2 octaves (for now), and it’s not temperature compensated (but that’s an easy fix).
https://electro-music.com/wiki/pmwiki.php?n=Schematics.VCO555ByThomasHenry
Has anyone ever given Thomas Henry’s 555 VCO a go? Always thought the sync on it sounded awesome. It was one of the first DIY projects I remember seeing but at the time I was scared off by it being +/-15V, and I couldn’t find a PCB anywhere. These days I would think about doing it on stripboard, but there’s too many projects in the way already
EDIT: didn’t see @BlackDeath post this first - regardless, would be good to know if anyone tried it.
Haven’t, no. But there’s a Eurorack PCB and panel available.
Ah no way! I think I was only looking at UK/EU dealers. Might have to pick that up
Thonk has it listed too, though out of stock.
Out of stock! Three words to inspire DIY
Yeah, unfortunately it’s been out of stock for a few years, so I’ve given up on it coming back
Is the Eurorack adaptation of the Thomas Henry 555 VCO published? You really only need to change the values of a few components to make it work on a 12V rail system. I believe there are already some tested PCB or veroboard layouts that can be copied.
555 circuits without v/oct are super simple:
Bang a few of those together and you’ve got a cool drone voice.
With v/oct, I think it’s a different issue…
Never saw a 555 circuit using only pins 1 to 4.
The 555 will astonish us for ever…
This is a bit above my pay grade, but it seems like this is the circuit to turn v/oct voltage into current values the 555 needs, and I’m guessing what the TH-555 uses:
Even without that, the simple 555 circuit is useful as a clock source if you don’t have a Keystep or something like that.
Somebody just posted another thread about this, using the CD40106:
Kristen Blåsol (who has an awesome YouTube channel) also used that here: https://www.youtube.com/watch?v=DtUCzzjHhgM
Not sure tbh! Been a long time since I looked around. I vaguely remember seeing a couple stripboard layouts but I don’t think any of them were confirmed working and all that
Check out the ohmsynth videos on the CD40106 as well!
Cd40106 is such a straightforward oscillation setup. Perfect for drones.
I looked around and here’s what I found. A 2012 forum post on electro-music in which Thomas Henry introduces the schematic for the 555 VCO.
Fonitroniks’ DIY page which gives parts lists and assembly instructions for several Thomas Henry designs adapted for Eurorack:
The two PDF files to download the are TH-555VCO-10HP.pdf and TH555VCO-BuildNotes.pdf.
This ought to be sufficient to enable somebody to build a copy on veroboard.
Well volunteered @Bitnik
