I’ve checked the keystep config in the PC Spftware for the keystep and tested both settings (V-Trig 5v and V-Trig 12v) for the gate output.
In order to test the output I connected a LED direct to the gate output with it set to 5V and it operates as expected (keypress lights LED, release turns off LED)
I believe I did warn that it’s not a very good VCA (Much like MIAW where I got it from warned.)
At the time I built mine I didn’t have anything that generated gates I could test with so I had also just used an LFO.
I just tested it with my keystep…and yeah…with the bias dead in the middle it almost works as expected - but it never fully mutes the signal so it just goes gets louder when I hit a key to send a gate.
But at any other point on the bias it works inverted.
So…it’s not you.
But I’m not sure if it’s my stripboard layout or Kristian’s original circuit I based it on. I’ll try and take a look at it later tonight and figure out which of us the blame falls on.
OK so I half fixed the issue…
Managed to stop the inverting by tying the 4.7k Resistor to ground rather than -12V.
This gives the correct operation of the gate closing when key is released.
However the issue with the gate not working unless the pot is in the middle (and not fully closing the VCA) is still there
Hmm…looking at my stripboard layout and the schematic Kristian provided…it looks they both have the 4.7k resistors going to -12 so that at least isn’t on me
I seem to remember in his video he mentioned that the VCA never really closed well and tended to bleed a lot of signal. In fact I got the impression from the video that he didn’t really recommend building this one…but I did anyway because it was simple and I had the parts on hand so even if it didn’t work well it would be better than nothing and I was able to toss it together in an evening.
Shortly after I made it I got my LMNC 1183 quad VCA and honestly haven’t touched this module since until I tested it today.
I probably never noticed it working inverted before because I only used it with an LFO and didn’t notice if it was triggering on the positive or negative.
Ahh… ill breadboard it out tomorrow and see if I can get something a little better working - I’ve already printed the panel so I’m not going to let this beat me
